05-20-2021, 11:04 AM #1
- Dec 2020
Ender 3 v2 Poor Quality Test Print
After importing the cube test print into cura i changed the profile to dynamic quality.
Did not change any other parameters.I printed a test print of the cube (will attach file) on my ender 3 v2
The results were not very good, will attach some photo's.Can anypme advise what could be wrong.
05-20-2021, 05:02 PM #2
- Apr 2021
- 186
Start by checking that your Bowden tube is fully secured at both ends, with no movement at the couplers. Also check belts are decently tight.
You can go a touch closer to the bed on your first layer too. I can see gaps between your first layer lines.
New member with print issue
