05-20-2021, 10:24 AM #5
the easiest way to get round it is to preheat the machine before running a print.
After a few minutes the filament stops oozing and you can pinch it off - I use fingers, other people with non-asbestos skin could use tweezers, paper etc. I just find fingers quicker :-)
I figure I've got enough hard skin after 8 years that the tips of my index finger and thumb are now pretty much fireproof :-)
One of the features of most slicers is to print either an outline of one or two lines before starting the print or just printing a line along one edge of the bed.
basically what you did manually - most slicers will do with a few ticks anyway :-)
The reason it happens is simple.
When you heat plastic (or anything) - it expands.
The cold plastic in the hot end - heats up and the expansion dribbles out the end.
This is why a pre-heat works well.
After afew minutes there is no more cold plastic to expand and the dribble stops.
If I'm doing a number of prints I keep the printer at temp inbetween.
That and the slicers pre-extrusion does the trick.
