Results 1 to 10 of 103
05-12-2021, 07:18 PM #11
- Apr 2021
- 70
with the glue after the fans finally kicked on the print almost worked but one little joint had come loose and moved away when I came back to check on it.
With the voxel I ended up using a raft on everything. It seems like that shouldn't be necessary but I am nearly at my wits end. It just takes so very little to disturb and displace these tiny little pieces and once it does the whole hours long print is ruined.
