Thread: Help with print errors please.
04-30-2021, 06:09 PM #1
- Apr 2021
Hi all.
Newish to 3D printing and I have been given a Lulzbot taz 6 that has been refurbished.
I have calibrated the extruder and flow rate but I am getting problems around the letters in this print for a stencil.
I am using a 0.5 nozzle. 215C extruder temp. 60C bed temp. 2.85mm Esun pla+ filament.
Cura Lulzbot edition.
0.25mm layer height. 0.5mm widths. 0.8 wall thickness.
45mm/s print speed. 45 infill. 22.5 outer wall speed. 45 inner wall.
1mm retraction at 10mm/s.
Could this be an overlap issue?
It also appears when i am watching it that after movement where it starts it misses a tiny amount. I assume its after a retraction.
Example where it started on the M.
Any help would be great.
I get the same problems on other parts I have printed before I did the extruder and flow calibrations.IMG-0453.jpgLast edited by jayuk022002; 04-30-2021 at 06:18 PM.
