Thread: Custom Shaped Hollowing
04-14-2021, 05:51 PM #1
- Apr 2021
Hi all. A friend and I were discussing possibilities and we were wondering if anyone had ever tried printing a 3D model with a custom shaped insert. We're printing in translucent UV sensitive resin on a Photon S. What we were thinking was having a 'blood diamond' in red resin, but we'd like to have a hollow inside of it shaped like a skull, so that you can rotate the model around and see the cavity. Does anyone know if this is possible and/or who might be making such models?
04-19-2021, 02:07 PM #2
pretty easy in openscad.
You'd just remove the skull model from the interior of the diamond.
Most cad packages should let you do this.
Cool idea too :-)
04-19-2021, 03:33 PM #3
- Apr 2021
04-19-2021, 04:55 PM #4
in openscad it would be a difference operation:
this is using a skull model I already had on my harddrive.
It won't look like much until you run it through a slicer :-)
here's the script:
$fn=12;
difference(){
translate([0,0,18])sphere(d=55);
translate([-20,-18,1])resize([40,40,40])import("c:/skull.stl");
} // end diff
Of course it helps to have a few skull models on the root of your harddrive :-)
I use them to make hinged moulds and then i use the clay skulls as slinging ammunition :-)
heres what you've got:
But in the rendered version the faceted sphere is solid and the skull has been removed from it's interior to leave a skull shaped void :-)
04-20-2021, 01:49 PM #5
And now I'm thinking: 'I;ve got a bunch of clear filament, this could be easily made to fit on an led tealight :-)
Watch this space lol
