04-20-2021, 05:17 AM #1
- Mar 2021
Failed print, curling on calibration Prusa Mk3S
Hi,
I am struggling to get any successful prints ( it was hit and miss before, now is 90% fail). I have attached the calibration square and you can see it curls a huge amount. I've also shown a print which fails on first layer. I have a Prusa Mk3S. I have tried two different PLAs and the same exact effect.
Any thoughts what might be causing the curling?
Thanks
04-20-2021, 06:59 AM #2
- Aug 2020
- United Kingdom
- 249
You have zero of very low adhesion to the print bed. Try setting the print head closer to the bed about 0.1 mm or 3 thou (0.003") And / Or use a bed adhesive like a thin layer of PVA glue stick Elmer or Prit depending on which side of the pond you are.
