03-30-2021, 03:13 PM #1
- Mar 2021
- 62
PrusaSlicer 2.3 settings for Ender 5 plus.
Hi.Please I have a problem with the lower layers of the printout and I don't know how to set up PrusaSlicer 2.3 correctly. Chip 0.4 does not place individual fibers next to each other but with a gap. The filament is PLA, the nozzle temperature is 220 ° C and the table temperature 55 ° C.
03-31-2021, 07:55 PM #2
Looks to me like you are printing the infill with a percentage. this could be normal.
To correct choose infill as solid or at least above 75%.
04-01-2021, 05:02 AM #3
- Mar 2021
- 62
Hi.
It's still the same, nothing has changed,
Thank you for answer.
04-01-2021, 07:33 AM #4
Did you download Ender 5 plus using.
Select Ender 5 Plus 3D Printer
Click Configuration > Click Configuration Wizard ...
Click Other Vendors Check the box Creality select Creality Ender-5 Plus to download Ender 5 Plus profile.
Then
Select Filament's you may use on your Ender 5 Plus 3D Printer
Click Filaments > Select Creality Ender-5 Plus and select (ALL) Types and (ALL) vendor then select all filaments you may be using.
