03-13-2021, 03:04 PM #1
- Mar 2021
Ender 3 pro - newbie wall gaps issue
Hi all, first print, first post!
Ender 3 Pro, Cura slice software
159175218_288363449304405_7447153906461391998_n.jpg158430527_1880663902083297_4580687090963789250_n.jpgScreenshot 2021-03-13 210241.jpg
I’m getting these gaps in my walls (they’re supposed to be flat vertical) and I can’t really find a similar example on the internet to refer to and tweak my settings.
Initial layer height: 0.24
Layer height: 0.2
Print speed: 80
Initial layer speed: 30
Retraction: 6 / 25
Not sure if there are any other settings you’d need so let me know.
I presume this is a newbie issue so hopefully someone can give me some pointers. Thanks in advance!
Ben
03-13-2021, 04:10 PM #2
What is you infill percentage set to.
This looks vaguely familiar.
Set your perimeter "vertical shells" to 2 or 3 walls printing perimeter first followed by printing infill with overlay to .025
03-13-2021, 04:47 PM #3
- Mar 2021
Hi thanks for the reply. Infill is 50%. I’m not familiar with those other settings but I’ll have a dig and see if I can find them!
03-13-2021, 06:11 PM #4
- Mar 2021
I can't find anything referencing vertical shells or overlay in the Cura settings - any ideas?
03-13-2021, 08:03 PM #5
It has been a while since using Cura mostly use PrusaSlicer 2.3.0 now.
Looked In Cura 4.8.0 and it is called Infill Overlap Percentage and Infill Overlap
