Results 1 to 10 of 10
Thread: Advice on HiRes printer choices
03-05-2021, 02:11 AM #3
- Mar 2021
Some answers
There should be minimal loading, the intention is to confirm "unloaded function", that is to say, do the bits work together correctly? This is intended to be a Proof of Concept before going to the much more expensive steel fabrication, and so the device function can be quickly and simply demonstrated.
I did my apprenticeship in both mm and inches, can machine to either thous or microns, but I got lazy I'll bear your advice in mind!
How do I learn the specifics of "Designing for 3d Print"? I use FreeCAD and am reasonably able with that, but it sounds like there is more to it...are there documents/videos that will help with my design style?
Thanks...I'll have a look.
Pretty handy...before I got into computer networking (I'm a freelance consultant) I was a ships engineer...you got to be handy when you're thousands of miles from anywhere and something breaks A kit sounds like additional fun!
