Results 1 to 10 of 24
05-08-2014, 04:39 PM #1
'New Matter' launching the MOD-t Affordable 3D Printer Soon via Crowdfunding Campaign
Looks like there will be a new crowdfunding campaign launching soon for a new 3D printer, called the MOD-t. It is from a company called 'New Matter', formerly known as IdeaShaper. They don't provide many details, but they are going to be "affordable". It should be interesting to see what the price will be, and if they try to compete price wise with the Micro3D printer that was just on Kickstarter.
Read more about this at http://3dprint.com/3413/new-matter-mod-t-3d-printer/
05-09-2014, 03:42 AM #2
- Apr 2014
- 228
They're a few weeks away from a crowdfunding campaign, and the best they have to show for their development is a rendering?
05-09-2014, 08:14 AM #3
- Dec 2013
- Georgia
- 934
A rendering that seems to have no y-axis and no reel for filament.
Either they really wanted this render to look clean, or they were lazy.
I'm sure they'll get millions and laugh all the way to Mexico.
05-09-2014, 10:13 AM #4
I've talked to some of the guys close to this company, and honestly I think they will be quite successful. Just my opinion though.
05-09-2014, 01:42 PM #5
- May 2014
- 14
Hi - I'm new to this forum. I've worked on the development of this printer, and I can assure you that the rendering is quite complete. Well, the filament spool is not shown, but the complete X-Y-Z mechanism is all there - it's just really minimal. I've done a fair amount of printing on a couple of their prototypes that are functionally equivalent but are not nearly as attractive as the rendering of the production design they used in their announcement. Unfortunately, I can't say much more until the crowdfunding campaign launches in a couple of weeks.
05-09-2014, 02:03 PM #6
- Feb 2014
- 29
Lobo, what are you feelings about it? Will it be something we want to buy and use?
05-09-2014, 02:31 PM #7
- Dec 2013
- Georgia
- 934
My apologies for the snark earlier.
I'm a bit curious though, how it moves in the x-y axis... At first, I thought I saw the plate attached to a threaded rod across the middle of the enclosure, but now I see that it's a smooth rod, at least in the render, which makes less sense for how the plate could move on it in both x and y axis on it. For that matter, now that I look again, it looks like the middle bar in the Z axis is smooth too, is the smoothness of the apparent driving shafts intentional, or is it for the cleanliness of the render?
05-09-2014, 03:35 PM #8
- May 2014
- 14
I hope you'll want to buy and use one. It's a very capable printer (ie, decent print speeds and good print quality) and they are aiming for really low pricing (they haven't settled on a final figure yet). The main advantage, though, is that it will be a very polished consumer device with much less of the fussing normally associated with 3D printers. In particular, they are working on a 3D marketplace that will essentially have pre-sliced objects that have been pre-tested with this particular printer, thus allowing the total novice to successfully print without having to know anything about the dozens of slicing parameters required for getting good results. (You'll also, of course, be able to design and slice your own objects if you have the know-how.)
05-09-2014, 03:41 PM #9
- May 2014
- 14
No worries - I appreciate your skepticism. What you can't really see in the rendering is another rod under the build table in the Y direction. These X & Y rods are not actually smooth but are toothed splines that drive the table in X & Y. And the center Z rod is actually a threaded rod. (The rendering doesn't really have enough resolution to make out these details.)
05-09-2014, 03:54 PM #10
- 462
You can just see the top of the hole for the y-axis rod immediately below the z-axis rod in the render.
