Thread: Print offset
01-29-2021, 04:46 PM #1
- Jan 2021
- Pacific Northwest
Print offset
Hey fellow makers! I am new to 3d printing and recently purchased an Ender 3 V2. Recently I took on a pretty daunting endeavor and purchased and downloaded the STL files for a Gyro Tourbillon. The main frame of the tourbillon is 216x216. I had to put the "travel avoid distance" value at 0 so that I could slice it with Ultimaker Cura 4.8. It sliced just fine and sits centered on the virtual build plate in Cura, but when I try to print it the model is offset and won't print properly. Somehow the model has shifted to the right and rear of the build surface. I was able to in Cura budge it over to the left by 3mm, but couldn't move it forward at all. I even tried setting the glass build surface back and to the right of the build table but was still unable to successfully print the model. I guessing it's an easy fix for you 3d gurus out there, but I really have no clue where to start to track down the issue I am having. Any help would be greatly appreciated.
