01-19-2021, 02:21 PM #1
- Jan 2021
Rubber/Soft Enclosure for 3D printed parts
I am using Ender Pro for 3D printing a few cuboid shaped enclosures. To give them a good cosmetic and a softer touch I want to cover the surface with some sort of material (like shape fitting soft rubber material) Any recommendations?
01-25-2021, 07:30 AM #2
well there might be a spray you can use.
But printing a thin cube with a soft flexible filament is going to be tricky even on a non-bowden printer.
If you go slow enough it might work - but I wouldn't like to put money on it.
A quick look shows various rubber sprays are available, here's a clear one: https://www.amazon.com/Rust-Oleum-26...1581040&sr=8-4
That's probably your best bet.
01-26-2021, 11:54 AM #3
Or Plasti dip.
https://www.amazon.com/Performix-075...s%2C206&sr=8-4
