01-15-2021, 10:25 AM #1
- Jan 2021
Flashprint 4.6 issue on Linux (with nVidia)
Does anyone know anything about using Flashprint in Linux?
I am experiencing some issue with Flashprint software dumping the core when reaching approx. 90% slicing.
The issue is only present on my machine with nVidia GPU present.
It works 100% fine with my 2x laptops using embedded Intel GPU.
It also works fine on this nVidia machine using version 4.5.2.
Here is a backtrace of the crashdump
Code:PID: 56248 (FlashPrint) UID: 1000 (kaipee) GID: 1000 (kaipee) Signal: 11 (SEGV) Timestamp: Fri 2021-01-15 16:08:15 GMT (3min 40s ago) Command Line: /usr/share/FlashPrint/FlashPrint Executable: /usr/share/FlashPrint/FlashPrint Control Group: /user.slice/user-1000.slice/[email protected]/app.slice/vte-spawn-bebd89fc-2dfb-4d69-8282-fab2f6d9a1ea.scope Unit: [email protected] User Unit: vte-spawn-bebd89fc-2dfb-4d69-8282-fab2f6d9a1ea.scope Slice: user-1000.slice Owner UID: 1000 (kaipee) Boot ID: e328874f44524160ae6a37c7f2c77ee2 Machine ID: 713d96a7166641ffb462bfdbd0d80f4d Hostname: arch-defined Storage: /var/lib/systemd/coredump/core.FlashPrint.1000.e328874f44524160ae6a37c7f2c77ee2.56248.1610726895000000.zst Message: Process 56248 (FlashPrint) of user 1000 dumped core. Stack trace of thread 56253: #0 0x00007fddc3755fc9 n/a (libGLdispatch.so.0 + 0x45fc9) GNU gdb (GDB) 10.1 Copyright (C) 2020 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-pc-linux-gnu". Type "show configuration" for configuration details. For bug reporting instructions, please see: <https://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from /usr/share/FlashPrint/FlashPrint... (No debugging symbols found in /usr/share/FlashPrint/FlashPrint) warning: Can't open file /memfd:/.glXXXXXX (deleted) during file-backed mapping note processing warning: Can't open file /memfd:xorg (deleted) during file-backed mapping note processing warning: Can't open file /SYSV00000000 (deleted) during file-backed mapping note processing warning: Can't open file /SYSV5101002d (deleted) during file-backed mapping note processing warning: Can't open file /memfd:/.nvidia_drv.XXXXXX (deleted) during file-backed mapping note processing [New LWP 56253] [New LWP 56265] [New LWP 56266] [New LWP 56258] [New LWP 56268] [New LWP 56297] [New LWP 56267] [New LWP 56277] [New LWP 56270] [New LWP 56249] [New LWP 56271] [New LWP 56280] [New LWP 56279] [New LWP 56291] [New LWP 56260] [New LWP 56274] [New LWP 56275] [New LWP 56248] [New LWP 56251] [New LWP 56252] [New LWP 56278] [New LWP 56250] [New LWP 56257] [New LWP 56255] [New LWP 56269] [New LWP 56263] [New LWP 56259] [New LWP 56256] [New LWP 56254] [New LWP 56261] [New LWP 56264] [New LWP 56262] [New LWP 56276] [Thread debugging using libthread_db enabled] Using host libthread_db library "/usr/lib/libthread_db.so.1". Core was generated by `/usr/share/FlashPrint/FlashPrint'. Program terminated with signal SIGSEGV, Segmentation fault. #0 0x00007fddc3755fc9 in ?? () from /usr/lib/libGLdispatch.so.0 [Current thread is 1 (Thread 0x7fdda9ef8640 (LWP 56253))] (gdb) bt #0 0x00007fddc3755fc9 in () at /usr/lib/libGLdispatch.so.0 #1 0x000000000075f851 in () #2 0x000000000075bfa2 in () #3 0x000000000075c24a in () #4 0x000000000075c1d7 in () #5 0x000000000075c360 in () #6 0x0000000000745179 in () #7 0x00000000007451dc in () #8 0x00000000006a45a2 in () #9 0x000000000067f215 in () #10 0x000000000067ecfa in () #11 0x0000000000676158 in () #12 0x000000000067a3a1 in () #13 0x000000000052105d in () #14 0x000000000053f5ce in () #15 0x000000000053c86c in () #16 0x00007fddc4bbaf0f in () at /usr/lib/libQt5Core.so.5 #17 0x00007fddc4a4e3e9 in start_thread () at /usr/lib/libpthread.so.0 #18 0x00007fddc481a293 in clone () at /usr/lib/libc.so.6
Login Error
