01-02-2021, 11:03 AM #1
- Jan 2021
Cannot get the right temperature for petg
I have a xyz printing da vinci 1.0 and i am trying to use petg. the only way you can change the extruder and bed temps is to re flash the eeprom chip in the filiment cartridge. i am using this coding- (look for the code that is in red text) every time i change the material from flex to pla to abs the temperatures are all wrong for petg. i have tried canceling out the materials part of the code but when i do that the chip remembers what the materials was from the previous re flash. does anyone know of a working program or coding to completely customize all of the temperatures or does anyone know how to change this code to make it work with the correct temps for petg?
Da Vinci EEPROM update Copyright (C) 2014 by Oliver Fueckert <oliver@voltivo.com>
Increment Serial code - contributed by Matt
UNI/O Library Copyright (C) 2011 by Stephen Early <steve@greenend.org.uk>
Permission is hereby granted, free of charge, to any person obtaining
a copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
the following conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. */
Pinout looking at the pads on the EEPROM board
| GND SCIO +5V \
#ifndef _NANODEUNIO_LIB_H
#define _NANODEUNIO_LIB_H
#if ARDUINO >= 100
#include <Arduino.h> // Arduino 1.0
#else
#include <WProgram.h> // Arduino 0022
#endif
#define NANODE_MAC_DEVICE 0xa0
#define NANODE_MAC_ADDRESS 0xfa
#define CODE 0x00 //1 Byte
#define MATERIAL 0x01 //1 Byte
#define COLOR 0x02 //2 Bytes
#define DATE 0x05 //4 Bytes
#define TOTALLEN 0x08 //4 Bytes
#define NEWLEN 0x0C //4 Bytes
#define HEADTEMP 0x10 //2 Bytes
#define BEDTEMP 0x12 //2Bytes
#define MLOC 0x14 //2 Bytes
#define DLOC 0x16 //2 Bytes
#define SN 0x18 //12 Bytes
#define CRC 0x24 //2 Bytes
#define LEN2 0x34 //4 Bytes
void IncrementSerial(unsigned char * cArray, long lAddress, long lSize)
unsigned char szTempBuffer[20] = {0};
memcpy(szTempBuffer,&cArray[lAddress],lSize);
long lSerial = atol((char *)szTempBuffer);
lSerial++;
sprintf((char *)szTempBuffer,"%04d",lSerial);
memcpy(&cArray[lAddress],szTempBuffer,lSize);
class NanodeUNIO {
private:
byte addr;
public:
NanodeUNIO(byte address);
boolean read(byte *buffer,word address,word length);
boolean start_write(const byte *buffer,word address,word length);
boolean enable_write(void);
boolean disable_write(void);
boolean read_status(byte *status);
boolean write_status(byte status);
boolean await_write_complete(void);
boolean simple_write(const byte *buffer,word address,word length);
#endif /* _NANODEUNIO_LIB_H */
#define UNIO_STARTHEADER 0x55
#define UNIO_READ 0x03
#define UNIO_CRRD 0x06
#define UNIO_WRITE 0x6c
#define UNIO_WREN 0x96
#define UNIO_WRDI 0x91
#define UNIO_RDSR 0x05
#define UNIO_WRSR 0x6e
#define UNIO_ERAL 0x6d
#define UNIO_SETAL 0x67
#define UNIO_TSTBY 600
#define UNIO_TSS 10
#define UNIO_THDR 5
#define UNIO_QUARTER_BIT 10
#define UNIO_FUDGE_FACTOR 5
#if defined(__AVR__)
#define UNIO_OUTPUT() do { DDRD |= 0x80; } while (0)
#define UNIO_INPUT() do { DDRD &= 0x7f; } while (0)
#else
#define UNIO_PIN 10
#define UNIO_OUTPUT() pinMode(UNIO_PIN, OUTPUT)
#define UNIO_INPUT() pinMode(UNIO_PIN, INPUT);
void sei() {
enableInterrupts();
void cli() {
disableInterrupts();
#endif
static void set_bus(boolean state) {
PORTD=(PORTD&0x7f)|(!!state)<<7;
#else
digitalWrite(UNIO_PIN, state);
#endif
static boolean read_bus(void) {
return !!(PIND&0x80);
#else
return digitalRead(UNIO_PIN);
#endif
static void unio_inter_command_gap(void) {
set_bus(1);
delayMicroseconds(UNIO_TSS+UNIO_FUDGE_FACTOR);
static void unio_standby_pulse(void) {
set_bus(0);
UNIO_OUTPUT();
set_bus(1);
delayMicroseconds(UNIO_TSTBY+UNIO_FUDGE_FACTOR);
static volatile boolean rwbit(boolean w) {
boolean a,b;
set_bus(!w);
delayMicroseconds(UNIO_QUARTER_BIT);
a=read_bus();
set_bus(w);
b=read_bus();
return b&&!a;
static boolean read_bit(void) {
boolean b;
UNIO_INPUT();
b=rwbit(1);
UNIO_OUTPUT();
return b;
static boolean send_byte(byte b, boolean mak) {
for (int i=0; i<8; i++) {
rwbit(b&0x80);
b<<=1;
rwbit(mak);
return read_bit();
static boolean read_byte(byte *b, boolean mak) {
byte data=0;
UNIO_INPUT();
data = (data << 1) | rwbit(1);
UNIO_OUTPUT();
*b=data;
rwbit(mak);
return read_bit();
static boolean unio_send(const byte *data,word length,boolean end) {
for (word i=0; i<length; i++) {
if (!send_byte(data[i],!(((i+1)==length) && end))) return false;
return true;
static boolean unio_read(byte *data,word length) {
if (!read_byte(data+i,!((i+1)==length))) return false;
return true;
static void unio_start_header(void) {
set_bus(0);
delayMicroseconds(UNIO_THDR+UNIO_FUDGE_FACTOR);
send_byte(UNIO_STARTHEADER,true);
NanodeUNIO::NanodeUNIO(byte address) {
addr=address;
#define fail() do { sei(); return false; } while (0)
boolean NanodeUNIO::read(byte *buffer,word address,word length) {
byte cmd[4];
cmd[0]=addr;
cmd[1]=UNIO_READ;
cmd[2]=(byte)(address>>8);
cmd[3]=(byte)(address&0xff);
unio_standby_pulse();
cli();
unio_start_header();
if (!unio_send(cmd,4,false)) fail();
if (!unio_read(buffer,length)) fail();
sei();
return true;
boolean NanodeUNIO::start_write(const byte *buffer,word address,word length) {
byte cmd[4];
if (((address&0x0f)+length)>16) return false; // would cross page boundary
cmd[0]=addr;
cmd[1]=UNIO_WRITE;
cli();
if (!unio_send(buffer,length,true)) fail();
sei();
return true;
boolean NanodeUNIO::enable_write(void) {
byte cmd[2];
cmd[0]=addr;
cmd[1]=UNIO_WREN;
cli();
if (!unio_send(cmd,2,true)) fail();
sei();
return true;
boolean NanodeUNIO::disable_write(void) {
byte cmd[2];
cmd[0]=addr;
cmd[1]=UNIO_WRDI;
cli();
sei();
return true;
boolean NanodeUNIO::read_status(byte *status) {
byte cmd[2];
cmd[0]=addr;
cmd[1]=UNIO_RDSR;
cli();
if (!unio_send(cmd,2,false)) fail();
if (!unio_read(status,1)) fail();
sei();
return true;
boolean NanodeUNIO::write_status(byte status) {
byte cmd[3];
cmd[0]=addr;
cmd[1]=UNIO_WRSR;
cmd[2]=status;
cli();
if (!unio_send(cmd,3,true)) fail();
sei();
return true;
boolean NanodeUNIO::await_write_complete(void) {
byte cmd[2];
byte status;
cmd[0]=addr;
cmd[1]=UNIO_RDSR;
do {
unio_inter_command_gap();
cli();
if (!unio_read(&status,1)) fail();
sei();
} while (status&0x01);
return true;
boolean NanodeUNIO::simple_write(const byte *buffer,word address,word length) {
word wlen;
while (length>0) {
wlen=length;
if (((address&0x0f)+wlen)>16) {
wlen=16-(address&0x0f);
if (!enable_write()) return false;
if (!start_write(buffer,address,wlen)) return false;
if (!await_write_complete()) return false;
buffer+=wlen;
address+=wlen;
length-=wlen;
return true;
static void status(boolean r)
if (r) Serial.println("(success)");
else Serial.println("(failure)");
static void dump_eeprom(word address,word length)
byte buf[128];
char lbuf[80];
char *x;
int i,j;
NanodeUNIO unio(NANODE_MAC_DEVICE);
memset(buf,0,128);
status(unio.read(buf,address,length));
for (i=0; i<128; i+=16) {
x=lbuf;
sprintf(x,"%02X: ",i);
x+=4;
for (j=0; j<16; j++) {
sprintf(x,"%02X",buf[i+j]);
x+=2;
*x=32;
x+=1;
if (buf[i+j]>=32 && buf[i+j]<127) *x=buf[i+j];
else *x=46;
x++;
*x=0;
Serial.println(lbuf);
int led = LED_BUILTIN;
These are the values to be written to the EEPROM
Make sure only one is uncommented.
By default its set for the starter ABS cartdridge with 120m of filament
Verified with firmware 1.1.I
// Value to write to the EEPROM for remaining filament lenght
// Default Starter Cartdridge is 120m
char x[] = {0xc0,0xd4,0x01,0x00}; //120m
//char x[] = {0x80,0xa9,0x03,0x00}; //240m
//char x[] = {0x80,0x1a,0x06,0x00}; //400m
// extruder temp, default is 210 C for ABS
//char et[] = {0xd2,0x00}; // 210 C
char et[] = {0xe6,0x00}; // 230 C
//char et[] = {0xf5,0x00}; // 245 C
//char et[] = {0xfa,0x00}; // 250 C
// bed temp 90 degrees, default ABS
//char bt[] = {0x5a,0x00}; //90C
char bt[] = {0x32,0x00}; //50C
//char bt[] = {0x28,0x00}; //40C
//Materials
//char mt[] = {0x41}; //ABS
//char mt[] = {0x50}; //PLA temp noz~ 200c bed~ 50c
//char mt[] = {0x46}; //Flex
byte sr;
void setup() {
pinMode(led, OUTPUT);
Serial.begin(115200);
while(!Serial);
delay(250);
void loop() {
do {
digitalWrite(led, LOW);
Serial.println("Testing connection to Da Vinci EEPROM CHIP\n");
delay(100);
digitalWrite(led, HIGH);
} while(!unio.read_status(&sr));
Serial.println("Da Vinci EEPROM found...");
Serial.println("Reading the Davinci EEPROM Contents...");
dump_eeprom(0,128);
//dump_eeprom(116,4);
//Read the serial number - added by Matt
byte buf[20];
memset(buf,0,20);
status(unio.read(buf,SN,12));
//Increment the serial number
IncrementSerial(&buf[0], 0, 12);
Serial.println("Press enter to update EEPROM...");
while(!Serial.available());
while(Serial.available()) Serial.read();
Serial.println("Updating EEPROM...");
status(unio.simple_write((const byte *)x,TOTALLEN,4));
status(unio.simple_write((const byte *)x,NEWLEN,4));
status(unio.simple_write((const byte *)et,HEADTEMP,2)); // extruder temp
status(unio.simple_write((const byte *)bt,BEDTEMP,2)); // bed temp
status(unio.simple_write((const byte *)mt,MATERIAL,1)); // Material
//Write the serial number
status(unio.simple_write((const byte *)buf,SN,12)); //Serial Number
status(unio.simple_write((const byte *)x,LEN2,4));
// same block from offset 0 is offset 64 bytes
status(unio.simple_write((const byte *)x,64 + TOTALLEN,4));
status(unio.simple_write((const byte *)x,64 + NEWLEN,4));
status(unio.simple_write((const byte *)et,64 + HEADTEMP,2)); // extruder temp
status(unio.simple_write((const byte *)bt,64 + BEDTEMP,2)); // bed temp
status(unio.simple_write((const byte *)mt,64 + MATERIAL,1)); // Material
status(unio.simple_write((const byte *)buf,64 + SN,12)); //Serial Number
status(unio.simple_write((const byte *)x,64 + LEN2,4));
Serial.println("Dumping Content after modification...");
dump_eeprom(0,128);
digitalWrite(led, HIGH); // turn the LED on
delay(10000); // wait for ten seconds
01-02-2021, 02:14 PM #2
- May 2018
- 566
On my MakeGear I use 235C and 70C for eSun and Overture PETG
01-07-2021, 06:10 AM #3
doesn't the slicer let you change temperatures ?
I knoiw the da vinci is ocked into stupid cartridges that have eeproms. But I also know that you can get round that.
But even so there should be some other way to adjust the print temps, ieither direct from the control panel or via the slicer.
