Thread: Octoprint Question
12-29-2020, 07:02 PM #1
Octoprint Question
A while back I hooked one of my printers to a Raspberry Pi and began using Octoprint. What a great way to control your printer. Now I want to have all my printers controlled by Octoprint but I am wondering what is the best way to go about this? Should I run multiple instances of Octoprint on one Pi or would it be better to have a Pi for each printer? Or does it make a difference one way or the other?Anyone that has experience with this I would really appreciate your input. Thanks in advance.
12-29-2020, 09:16 PM #2
A raspberry 3 can run one 3D Printer using Octoprint trying to operate two would most likely be too much for a single Raspberry Pi 3.
Run a single raspberry Pi 2 with Octoprint an install the Plugin Octolapse the print quality drop enough too show a fuzzy texture on models.
Attached is a photo of one model printed with Octolapse an the other with SD card without telling you which is which look an see.
So my suggestion is each 3D Printer gets a Raspberry Pi 3 or better.Last edited by Roberts_Clif; 12-30-2020 at 08:56 AM.
12-30-2020, 11:54 AM #3
Thanks Roberts_Clif. That's the way I'll go.
01-01-2021, 08:18 AM #4
After Returning to the OctoPrint web site and reading found this updated Download information Octop1 0.17.0
Recommended hardware: Raspberry Pi 3B, 3B+ or 4B. Expect print artifacts and long loading times with other options, especially when adding a webcam or installing third party plugins. Setups not using recommended hardware are not officially supported.
Image compatible with Raspberry Pi A, B, A+, B+, 2B, 3A+, 3B, 3B+, 4B 1/2/4GB, Zero and Zero W.
01-01-2021, 10:43 AM #5
Thanks for the help. I have some Pi 4B's coming from Amazon.
01-01-2021, 11:03 AM #6
Am talking to Adafruit as have a bad Raspberry Pi 3B hoping to get warranty on, then I will be purchasing a pair of raspberry Pi 4 2GB's
