Thread: Ender 3 Pro Screen Issue
12-25-2020, 04:15 PM #1
- Dec 2020
Hello! I recently got a Creality Ender 3-Pro 3d printer and i am having an issue where if i put an sd card in it's slot,the screen does not work, and if i turn it on without the sd card,then insert it, it does not read the sd card. I want to know if anyone else has had this issue, i wish to find help.
Also, if i put the sd card into my computer,it does not read it.The sd card i am using is the one which came with the 3d printer.
And the error first happened while i was printing an object.Last edited by hardcorescythe; 12-25-2020 at 04:18 PM. Reason: not specific enough
12-28-2020, 10:44 AM #2
- Dec 2020
- N colorado
- 19
Sounds like you’re SD card is bad.
12-28-2020, 07:25 PM #3
The SD cards that come with some 3D Printers are only good for one thing the circle file (" garbage can ").
Purchase a few new ones format using a SD card Format program not windows then it will work correctly.
