Results 11 to 20 of 39
Thread: Built Printers
05-06-2014, 07:20 AM #11
- Dec 2013
- Georgia
- 934
05-06-2014, 01:05 PM #12
- Apr 2014
- 88
what's up Pete, how goes the build? I want to see your system setup even if you're not printing yet, I have to live through you guys until I get mine.
05-06-2014, 01:38 PM #13
Colehard, I agree with Anuvin and must add :
- It's a Beta kit. Beta mean functionnal, but expect bug, incompete stuff and other stuff that need improvement. If you have idea, post them on the beta forum to improve the product ! It's what Beta is for ! (Beta seems to be missunderstand as "early access").
- Resine is shipped separely (from MakerJuice directly), you will receive it later. Anyway, try to focus on the build and instructions at first, you'll be better at printing !
- Container have always been sold in a another package. It was 50$ If I recall (for mount and container).
- UV were on the P28 kit, but wasnt very efficien, so they have been removed from PP29. Might see them back in PP30 or consumer release.
Laser is not very powerfull, but still dangerous. You can add a safety switch if you wish. Come on beta forum, I'll explain to you how to do it.
05-06-2014, 04:48 PM #14
- Nov 2013
- Cambridgeshire UK
- 55
Ask and you shall receive....all be it a fairly minor update (unfortunately I gashed my thumb in a stupid drilling accident, n.b. salt water and cuts do not mix!)
I have:
Added the top and bottom reservoirs
A front and back bar on my frame
Trimmed the 'zero' point on the circuitry
Added drip rate attenuator (see below it's just a drilled steel plate but sounds fancy!)
Drip system working and calibrated
Added two safety switches (on the left)
Unfortunately work prevents play but I'm hoping to get going again at the weekend and hopefully calibration and basic prints should follow shortly.
Last thing I'll share that excited me massively was getting the mirrors moving for the first time, the peachy software allows you to draw some pre-defined patterns, it's pretty easy to guess what this would be drawing.....
05-06-2014, 05:09 PM #15
- Apr 2014
- 88
please tell me you plan on putting in a viewing window, it would suck not being able to watch it print.
05-06-2014, 05:33 PM #16
- Nov 2013
- Cambridgeshire UK
- 55
There's a webcam to go in the box so I can monitor it remotely (and one of my friends has promised he can sort a web feed for you peeps), when I get hold of some laser protection acrylic then I'm planning on routing out a window into the door....or if it's cheap enough then I'll replace the whole back with a massive sheet
05-06-2014, 05:55 PM #17
- Mar 2014
- 9
Thanks for the update!
Pete,
Thank you for that update, keeps me very happy and excited to see the progress.
Was moving the mirrors done through Blender, or was it done through some sort of calibration program?
I am just so amazed at how this thing operates. Can't wait to get mine! After beta anyway
05-06-2014, 05:57 PM #18
- Apr 2014
- 88
05-06-2014, 06:25 PM #19
- Nov 2013
- Cambridgeshire UK
- 55
Calibration program. For the moment the peachy tool chain is not run through blender, they are working on that and I should expect that will still constitute the main mode of operation by the time users get devices.
Oooo close, but I'm much more of a cheapskate in this area, it's a c270 (but respect none the less).
I have somewhat of an LED fettish, I go from uW (I have one in an acrylic block I made, I'm aiming for 15 years!) to 100W (Ouch!). I'll sort something in this area I suspect :-)
05-06-2014, 08:38 PM #20
- Dec 2013
- Georgia
- 934
The mirror video is strangely mesmerizing.
This is definitely turning out to be a solid example of how to build a Peachy right.
New member with print issue
