Results 1 to 9 of 9
Thread: Anycubic i3 Mega S - Oh nuts!
11-19-2020, 07:02 AM #3
- Nov 2020
Hi,
I recently bought an Anycubic i3 Mega S.
I was having an issue with the first layer that a tip from curious aardvark on this thread I started, helped me solve: https://3dprintboard.com/showthread....d=1#post145228
I belive that you can also find good loan options if you check out the best payday loan service in the web called
Essentially, I didn't realise that the bed-level needed to be checked frequently, as the vibrations during printing throw it out of whack. curious aardvark suggested locking-nuts, so I designed and print some into which you just need to fit M3 nuts. A good reasonably firm tap with a hammer settles the nut in place. A slightly-too-small hole behind the nut to increase the friction so that vibrations don't shift it. The idea seems to work.
I have attached the STL here in case anyone finds it helpful for their printer.
CheersLast edited by samll; 07-29-2021 at 02:27 AM.
