01-14-2019, 09:57 AM #1
- Jan 2019
Simplify3D - Bed probing and print area placeholders - Gcode script
Hi all,
my printer has a really big bed and often I just need to print small object on different bed areas. So an high-definition probing (with a BLTouch) on the whole bed area can result in a useless and really time consuming activity.
So I'm looking for a way to probe, before each print, only the bed area affected by the print itself.
To obtain this result I need to set the probing grid in the GCode "starting script" using a dynamically composed M557 command, but at this stage I also need some sort of Simplify3D variables in order to "know" the maximum and the minimum X and Y value used in the print process.
Ideally I would obtain something like:
Code:M557 X[min_x]:[max_x] Y[min_y]:[max_y]
Thank you!
Luke
P.S. =I'm using Simplify3D v. 4.1.1 + RepRap + Duet
12-10-2019, 11:42 AM #2
- Dec 2019
11-18-2020, 03:10 AM #3
- Nov 2020
Yes, you can go with sedersmith or find an path which can help you give out things well.On the off chance that anybody is intrigued, my companion and I built up a Cura post handling content (he did the crucial step). I truly figure this would be lucky to be a firmware highlight, similar to I composed a solicitation for. Yet, in the then, for those utilizing Cura: You pass it a solitary boundary (work dividing worth), and it parses the main layer gcode for min/max X and Y directions, and afterward replaces the M557 line in your beginning gcode. LevelingMeshOptimizer.py.txt Simply eliminate the .txt, and drop it here: C:\Program Files\Ultimaker Cura 4.5.0\plugins\PostProcessingPlugin\scripts\ You should have a static work leveling order in your beginning gcode, as: M557 X0:200 Y0:200 S20This, query has been strucking all over, do you think it works out? Let me know with it.
11-18-2020, 09:01 AM #4
- Jan 2019
Hi equlyhenna,
thank you for your reply and congratulations for your work.
Meanwhile I've discovered that Simplify3D 4.1.2 natively offer the placeholders for the maximum and the minimum X/Y values, so the task has become a breeze. ;-)
06-24-2021, 02:57 AM #5
Hi,
I'm looking for undocumented (custom) placeholders for post-processing scripts.
By the way, if you need custom Simplify 3D G-Code, there's a good source > Bob's Project Notebook and custom term papers by Bob George.
Login Error
