Thread: 3D Cad Software
11-02-2020, 02:11 PM #1
- Oct 2020
- 10
3D Cad Software
Could anyone recommend a decent 3D CAD Software that is free and similar to SolidWorks or Inventor?
11-02-2020, 06:51 PM #2
11-03-2020, 04:40 PM #3
- May 2018
- 578
Onshape is free but your models are open to any other user of onshape.
Just made a custom sanding adapter for my Rockwell multipurpose tool today. Worked out great!
11-08-2020, 09:51 AM #4
- Nov 2020
- Oxford, UK
- 12
Same boat. I used to use CorelDraw from early 1990s and found it great. Guess I got used to it. Also used IntelliCAD for dxf outputs by CorelDraw. And then HullForm to take the offsets from CD and develop the steel plating for a 22m vessel.CorelDraw was good in that it was very easy to adjust properties of an object. Almost intuitive. Select an object and its properties were simply displayed - dimensions, angles, thicknesses, fills etc. Just drew a box in Sketchup and no obvious object properties to simply adjust length and width??And prefer to download as I am often not connected to the www.
06-13-2022, 06:07 AM #5
- Jun 2022
You can try with FreeCAD, Fusion 360, and Meshmixer.
Design not printing solid
09-17-2024, 06:12 AM in 3D Modeling, Design, Scanners
