Results 11 to 20 of 36
Thread: i need help badly
10-31-2020, 06:25 PM #11
Sounds good.
Let's start by talking about which firmware you have loaded.
Ender 3 Firmware + Source Code + SD Files + BL Touch
or
Ender 3 Pro Firmware + Source Code + SD Files + BL Touch
or Other.
11-01-2020, 07:34 AM #12
- Aug 2020
- 29
i have the first firmware
11-01-2020, 09:39 AM #13
When you first turn on 3D Printer what temperature reading do you have for your Hot-end and Hot-Bed.
11-01-2020, 01:48 PM #14
- Aug 2020
- 29
357 for hot end 22 for bed
11-01-2020, 04:14 PM #15
Thermister is shorted with a reading 310 °C or higher.
I would suspect that the Thermister is shorted unplug and measure the resistance of the thermister at room temperature Post resistance.
With Hot-end Thermister unplugged from controller board again turn on 3D Printer and post reading.Last edited by Roberts_Clif; 11-01-2020 at 04:35 PM.
11-01-2020, 08:06 PM #16
- Aug 2020
- 29
so i lossened the bolt that was holding the thermistor and plugged it back in and it is reading 26 also it is putting out filament now
11-01-2020, 08:51 PM #17
- Aug 2020
- 29
the filament did not look very melted though
11-02-2020, 06:05 AM #18
11-02-2020, 04:31 PM #19
- Aug 2020
- 29
i have only had one filament it is solutech it is around a year old and was stored on the printer the hot end was set to 220
11-02-2020, 06:49 PM #20
Then if it does not look very melted it must not be PLA what filament type are you printing with.
Have you tried to print a Temp Tower to determine what temperature it print best at.
