Thread: Thermal Runaway E1
10-12-2020, 03:02 AM #1
- Oct 2020
- 13
Thermal Runaway E1
I am currently building a Hypercube Evolution from a kit that was passed on to me. It uses a BIQU KFB2.0 control board and a 24 volt power supply. I have no prior experience in 3D printing.
I was getting to the end of the build. Everything was working. I was testing every component as I added it using Pronterface. I have not covered the aluminium heated bed with anything as I did not want to cause problems for the the induction sensor (used as Z Min endstop). The induction sensor has a 4mm range for ferrous metal and less for aluminium. I was intending to print on blue tape.
One website I visited suggested using feeler gauges as a better choice when levelling the bed. So I did. What I did not know is that both the hotend and the bed have power running to the outer surface. I found out when a feeler gauge touched the bed and the hotend at the same time. Since then, my LCD display gives the message "Thermal Runaway E1 press reset". I have pressed reset on the control board to no avail. Short press, long (5 and 10 seconds) and double press. None of which work. I have disconnected the hotend and it's thermistor from the control board. I have tried using another thermistor, but to no avail. Pronterface, when trying to connect, gives the following two lines:
"Error: Thermal Runaway, system stopped! Heater_ID: 0
Error: Printer halted, kill() called!"
I have also re-compiled Marlin 2.0.6.1 using Auto Build Marlin and uploaded to the board, still the error persists. Anybody any idea how to fix this problem?
11-01-2020, 12:30 AM #2
- Oct 2020
- 13
Found out. Board is dead. Had to buy a new one.
