Results 1 to 10 of 12
10-19-2020, 05:02 AM #1
- Oct 2020
- 6
PLA doesn't print well on Ender 3 Pro, using Cura
Hi everyone,
I have a new Ender 3 Pro printer, and am using Cura as my slicer of choice (set to PLA / ABS according to the material I'm printing with).
ABS prints come out very well, but the PLA prints are lousy: very low resolution for some reason, and lots and lots of 'spills' and thin strands of material that gets dragged behind the extruder as it moves.
What do you think might be the cause? Would appreciate any advice!
You can see pictures here -
10-19-2020, 08:40 AM #2
Please Post Images.
Probable Cause -filament adsorbed moisture.
Solution - Using a dehydrator
Type Temperature Glass Transition Duration PLA 122° F 140-150° F 8 Hours PETG 140° F 165-175° F 4 Hours ABS 158° F 220-230° F 4 Hours
10-19-2020, 10:30 AM #3
try using prusa slicer (does anyone really use cura through choice ?)- and it's most likely not moisture - never had any issues with that and pla.
I guess you'd need to have the filament somewhere really humid for some time, for that to be an issue.
Did you change the printing temperature between abs and pla ?
Printing pla at abs temps would cause the described problem.
Basically give us as much information as possible.
Just saying: 'this did not work - tell me why'.
Without supplying any details, does not help :-)
10-19-2020, 12:55 PM #4
- Oct 2020
- 6
10-19-2020, 01:31 PM #5
- Oct 2020
- 6
Ah, sorry. I'm not used to asking for help on these issues So - The printer is a new one, basically two weeks old. Creality Ender 3 Pro. It managed to print some intricate creations in ABS, but since I'm printing inside the house and with no good ventilation, I prefer working with PLA.The issue started with the CR-PLA filament (freshly opened). Lots of stringing, as you can see in the pictures. I only tried printing two things, though: the Spiderman body and the Print in Place Engine Benchmark. Both came out in pretty bad shape, with the engine being so messed up that it couldn't work properly.I'm using Cura 4.7, with a setting specifically for Creality Ender-3 Pro. Layer height = 0.2 mmInfill % = 20%With supportPrint speed = 50 mm/sPrinting temperature = 200 CBuild plate temperature = 60 CPrint Cooling is enabledFan speed = 100%Retraction is enabled, and I tried using a "retraction minimum travel" of 1.5 mm (default), 1 mm and 0.7 mm (lowest setting). The stringing was still apparent in all of these settings.The other retraction settings can be seen in this link - https://photos.app.goo.gl/HC4wfcj3kzNCK4YY9Finally, it's also possible that I have a missing layer problem, as can be seen in the following image (which was printed with a retraction minimum travel of 0.7 mm.https://photos.app.goo.gl/upeCHNWww8AV9R1n9I think that's all the information I have right now, but would love to provide you with more if you direct me.Thank you for your time and attention!
10-19-2020, 03:28 PM #6
You were printing with ABS an then switched to PLA.
Did you Purge the ABS from the hot-end by running PLA to the ABS temp and Pushing Extra ABS from the Hot-End.
10-19-2020, 05:13 PM #7
- Oct 2020
- 6
10-20-2020, 05:55 AM #8
okay well at least part of the problem are your retraction settings.
you have a bowden printer - so anything under 3mm is just not going to work well - period.
Try setting retraction 4mm and 65mm/s retraction speed.
secondly - never use built in standard type profiles. always best to learn how to use a slicer - but cura sucks, get prusaslicer.
and change the retraction settings :-)
Then get back to us.
Creality filament is usually pretty decent stuff. so it's not likely that.
your temps are fine.
10-20-2020, 01:28 PM #9
- Oct 2020
- 6
Thanks again for the help. I tried printing again via Cura with the new settings you recommended. I then tried to print the same thing via Prusaslicer (with the temperatures set to 210 C for the extruder, and 40 C for bed). Both prints came out with stringing, though the Prusaslicer one was a little cleaner... but still very messy.
See image of the two side-by-side (Prusaslicer to the left, Cura to the right) - https://photos.app.goo.gl/Hx9YNXqT5gsErnLB7 So it doesn't look like it's working
What do you think?Last edited by dup; 10-20-2020 at 03:08 PM.
10-21-2020, 09:53 AM #10
ewww - that's not stringing - that's either a partially blocked nozzle or a partially blocked nozzle :-)
Or dodgy filament that's blocking the nozzle.
have you got any other pla to try - that might be a duff roll.
I haven't had many bad rolls, but that's pretty much exactly what happens when you get one.
You might also need to change the nozzle. Yeah you can try and clean it up - but at about 50p a nozzle - it's usually easier just sticking a new one in.
And if you clean it with any kind of metal tool - it usually buggers it up anyway.
Bed temp 40c - is kinda low. bit if it sticks it sticks :-)
