Thread: constant oozing extrdr R
04-29-2014, 09:39 PM #1
- Apr 2014
got constant oozing. see picture flashforge creator dual
whom to blame and from where to buy the parts
thanks
04-29-2014, 11:15 PM #2
- new jersey
- 752
it will always ooze, ,some plastics worse than others but if its excessive then that can be from moisture in your filament. why do you need parts? is it broken?
05-03-2014, 06:27 AM #3
- Apr 2014
i been guessing the filament feeder motor got current all the time when print, meaning, bad stepper driver controller
to check you suggestion will move the flmnt to L extruder
05-06-2014, 03:28 AM #4
- Apr 2014
today 06 05 checked put the flmnt from L xtrdr which was behaving ok, to R xtrdr. result-- is oozing, problem not from flmnt
New member with print issue
