Results 1 to 10 of 50
08-28-2020, 11:16 AM #11
- Oct 2016
- 184
You'll get there too. It took me quite a lot of time to get things tuned so that the quality and realiability is decent. And there's still rooms for improvement, but I'm quite happy how things work at the moment.
Also the filaswitch development has taken quite a lot more time than I anticipated. I mean, how hard it is to do a post-processing script that just adds few lines of gcode to existing gcode-file? Well now the project has been under development since 2017, has 434 commits, few thousand lines of Python code and I still find random bugs and things to improve now and then..
Printed a dual color rose as a gift. The stem is printed separately and glued to the petals. Model: https://www.thingiverse.com/thing:2354319. Used FrankenCube for a change, I haven't done any prints on it for a while, nice to see that it's still working as good as it was. I dried the filament properly and might be that there's bit less stringing vs the last time I printed PETG with this printer.
I kept the purge tower/purge amount quite small as the color contamination is actually a good thing in this model, the clear PETG has some red on it.
Assembled the 6x feeder with multiple 2x feeder modules. Don't look like much but after short testing it seems to work. In future, it's best not to use capricorn tubing for the feeders, it's simply too tight when clamped inside the feeder parts. Had to do some fine tuning and now it's not too restrictive, but regular PTFE tube seems to work better in this case.
I did only one test print with two colors, a dual color fidget widget https://www.thingiverse.com/thing:1775648. Currently don't have enough different color PLA, so need to order more colors. But 6-color prints are on the backlog...
Ordered one set of genuine Bondtech gears. Readl deal on the right. More shiny than the chinese clones. Better? Don't know yet.
