Results 1 to 8 of 8
Thread: Wood filament
08-20-2020, 12:49 PM #8
PETG requires a bit more squish than PLA, although there is a sweet spot that works well for both. Also, depending on the print surface, you may want a release agent. I've seen where it has stuck so bad to glass that people have torn off chunks of the glass bed, same with a smooth spring steel sheet. Textured sheets seem fine without a release agent, anything else, lay down some glue stick or some windex.
