08-16-2020, 10:04 AM #1
- Aug 2020
Dynamo D3D One Pro printer problem
I recently bought one of these large, fast, printers but have a problem getting it to print.
After levelling the bed, heating hotend and bed, loading filament and a GCODE file, the machine "homes" and centres but before starting to extrude the bed drops by about 35 - 30mm and I end up with "spaghetti" on the bed rather than a print.
Can anyone offer a reason or better still, a solution ???
08-17-2020, 11:58 AM #2
what slicer are you using ?
see iof there's a command that looks something like this
G1 Z30 F600
for most systems G1 commands are movement commands. So that command would move the z axis 30mm in a positive direction. Assuming you home at Z0 that would drop the bed by 30mm
I believe the F600 is a speed command for 'quite slow' - at least that's what it said when I was copying it into an ending script last night :-)Last edited by curious aardvark; 08-19-2020 at 05:55 AM.
08-17-2020, 12:00 PM #3
- Aug 2020
I use Cura
08-19-2020, 05:50 AM #4
check your starting g-code - sounds like there's something there that shouldn't be.
08-19-2020, 06:05 AM #5
- Aug 2020
I'm afraid I don't know how.
08-19-2020, 11:17 AM #6
I xan almost guarentee that there is a youtube video that shows you how :-)
I haven't looked at cura for years - but lots of other people have and many of them have made instructional videos :-)
