Results 1 to 10 of 10
Thread: Missing holes
08-08-2020, 08:42 AM #2
Meshmixer found one non-manifold area and two holes in the mesh. Those problems appear to be associated with a surface of zero thickness on the the left side of the STL. There also appear to be other smaller surfaces of zero thickness on the right side of the model. Meshmixer wasn't able to fix the problems. How did you make this STL?
