Results 1 to 10 of 11
08-06-2020, 11:09 AM #4
Hmm tricky opne.
The he3d k200 was my 3rd printer, and while after three years it's still factory spec hardware, electronics and firmware - I did make some mods to improve things.
I wouldn't necessarily recommend a delta as a first machine. But that said it's had over 7km ! of filament through it in the last three years and never put a foot wrong that wasn't my fault.
Without my mods and the sheet of Printbite I print on - it might be a bit trickier.
My first machine - flashforge creator was a real hit or miss affair until I stuck the Printbite sheet to it. And once your first layer and removing finished print issues go away - life is so much more fun :-)
So with the delta I ordered the printbite at the same time as the printer. So I've never had any adhesion issues with it.
And all the mods can be printed by the machine.
https://www.thingiverse.com/thing:2386628
for the flexible cable manager you'd need to go down to about 10mm/s with a fairly stiff flexible filament - but I believe I printed the one I'm using with the delta.
On the up side - I can help :-)
I guess it depends what you think you're mainly going to print ?
Other than that, my best advice when looking at I3 style printers is to stick with josef prusa's original design.
Direct drive extruder
Dual z-axis motors
Print bed side support rails.
That way you at least start with a machine that has very sound engineering.
