Results 1 to 8 of 8
Thread: Ultimaker 3 Extended TPU Print
06-25-2020, 03:15 PM #6
Yeah but on a square build plate with a fixed height extruder the odds are the printhead will crash into the already completed model.
You can get away with it on a delta, but not usually on this style of printer.
If slowing down helped then increase the printing temperature.
One thing I've never had any problems with in flexible filaments is layer adhesion.
The flexible pla I prefer to use the later adhesion is perfect. The prints are unbreakable without using power tools.
Tpu is weird stuff, it can often print best at temps much higher than the manufacturers state.
And NEVER use manufacturer or slicer standard profiles :-)
