04-19-2020, 06:58 PM #1
- Apr 2020
Newbie Help Needed with Monoprice Select Mini IIIP
I have a Monoprice Select Mini 3D printer 115365, and I just got new PLA filament. When I go to print, as the extruder is moving to the starting position, the filament starts to come out. This causes the print to not work. The filament just becomes a big mess. How do I prevent the filament from coming out before the printer is ready? I tried lowering the temperature of the extruder and the plate, but nothing is working. Could it be bad filament?
04-21-2020, 10:11 AM #2
just pick the filament from the nozzle before it starts to print.
If you have delicate skin, use tweezers, I just use my fingers.
05-03-2020, 04:12 PM #3
- Feb 2017
- 19
That is the printer priming the nozzle. There is lines in the starting G-code that you can edit if you know how to access them in your slicer.
You will always get a little drip but if it’s a lot I bet that’s the cause. Unless you start prints remotely it is best just to clear it with long tweezers or your finger as curiousArdvark said. it helps the print start.
