04-05-2020, 10:36 AM #1
- Apr 2020
filament stuck all over the nozzle
(don't ask me about the model, it's a custom build)
after an software error my 3d printer started extruding downwards and grabbed the whole printout with it, the result looks like that messs.jpg.
what can i do to get rid of the filament? please help.
04-05-2020, 01:05 PM #2
- Apr 2020
- Middle of the UK
- 16
Assuming the extruder is well attached and not a weak point i would just twist it off. If thats risky use side cutters to remove some or
warm it with a hairdryer/hot air gun.
04-05-2020, 01:08 PM #3
- Apr 2020
it,s like all over the extruder... so much that you can't even see it. i'll probably try the second method but i doubt it will work.
04-27-2020, 08:50 AM #4
- Jan 2020
- Bel Air Md
- 181
I had that happen to my ender 3pro about 2 weeks ago. Was all over nozzel up and over fin thing. I would up disassembling and slowly breaking off runaway filament. Once cleaned off I reassmbeled hot end. Then thru temperature control I heated up nozzel to 200 and left for a min or two, After I pulled back filiament in boden tube feww inches. After that Ive had no more issues with that
