04-05-2020, 01:02 PM #1
- Apr 2020
- Middle of the UK
- 16
Printing small text and fine lines with SLA (Elegoo Mars)
Recently purchased an Elegoo Mars after having a CTC MakerBot clone for many years.
1st print failed, nothing stuck to the bed but I levelled the build plate again and it seems good now. Will the bed stay levelled if gentle when removing parts?
2nd print worked, it was a skull ring from Thingiverse with way more detail than the FDM printer could manage so happy with that.
Trying to print a pendant 1st one at 35x25mm, was too small and lacked a lot of detail. 2nd one from the same file 42x36mm was better but not quite there.
Text was faintly visible on the surface but seems to be too small.
Am I asking too much of it? Or is this a settings issue? Using Chtubox slicer with the standard 0.5mm settings.
Thanks.
04-05-2020, 01:07 PM #2
0.5mm setting ?
seems a bit big for an sla - but you don't say what the 0.5mm is applied to.
04-05-2020, 01:20 PM #3
- Apr 2020
- Middle of the UK
- 16
Sorry 0.05mm Layer height. Tried printing the item flat (small one) and vertically (larger one)
