Thread: noobie here. help please
03-24-2020, 05:40 PM #3
- Mar 2020
I have a longer LK4 pro. 220x220x250mm
using Cura 4.5
I am running off SD card that came with printer.
The first two files were already gcoded on the card.
The one that wont run I sliced myself. but then I went back and got a file off the SD and sliced it.
That file is running now.
the file that wont run is for a box I want to make.
When I first sliced the file I got it from the sd card. Cura did its thing and I saved the file onto the sd.
but it wont run.
The first time I tried, I copied the stl file onto the sd card and tried to run it . doesnt show on printer screen.
so I put the sd back in computer and started cura. I chose the file from the sd card and sliced it with std settings.
I put the sd back in printer and chose it. then warmed up table and nozzle and pushed start.
It went to a corner and stopped there and just sat there for over an hour.
printer screen shows ET and progress but no error code.
That is when I chose a file from the sd card and sliced it.
it is running now.
Im thinking it may have limited out on Y travel.
but it gives no error code.
I just now loaded the file into cura from my computer HD and now it wont slice.
It says: Unable to slice
then: none of the models fit the build volume. please scale or rotate the model to fit .
I am now trying to learn how to manipulate cura.
do you have a YouTube video to recommend?
