Thread: Flashprint issues
03-16-2020, 02:27 AM #1
- Mar 2020
Flashprint issues
Hi Guys,I am considering buying a flashforge Adventurer 3, I have downloaded Flashprint and have imported a .stl model of a house which when I prepare it for printing the doors and windows are missing, im guessing they are too thin to print??is there a setting that will enable them to print? I want the internal of the house hollowmany thanks in advance.
03-16-2020, 07:26 AM #2
well it dependrs how thin they are.
if they are thinner than the nozzle width - then they won't appear in the sliced model.
If you can't edit the model then you could change the nozzle for a smaller diameter. 20 0.3 or 0.35 instead of 0.4
Had a look through flashprint and I can't see any option for nozzle diameter. The closest I can find is 'path width'.
Adjust that and resclie the model - if the window and doors appear - then that's what's causing it.
03-16-2020, 09:50 PM #3
- Mar 2020
Many thanks for that, have decided on an Artillery Sidewinder instead because of the printing size.
so will be using Cura.
is there a specific setting there? that will make windows show up.
many thanks.
03-17-2020, 06:59 AM #4
forget cura use prusaslicer.
Considerably more user friendly and designed for i3's whereas cura is designed for, well nobody lol
It's horrible :-)
08-25-2020, 01:00 PM #5
- Jul 2020
I would also prefer Prusa Slicer - but unfortunately I can't get it to work with my Adventurer 3
