03-11-2020, 09:04 AM #1
- Mar 2020
New to 3D printing. Want to make functional parts for business
I repair old telephones. (Not cell phones) I have played a little with 3d printers over the years... just a tiny bit. I do have 2 laser engravers and often make flat parts with them. I am looking into the possibility for making more intricate replacement parts such as battery covers on older cordless phones, antenna housings (empty semi-flexible plastic tube) maybe even button caps (white plastic caps with black dial pad numbers, tiny power switch plastic slider, etc...
Basically I'm not interested in making toys. I need functional parts and I need them to look reasonably nice (not the typical texture from 3D parts pulled right out of the printer)
There are so many choices and thins to look at. I'm hoping someone can help narrow down the search or provide recommendations.
I don't need to print anything large. 6" bed would be fine.
Also, what is the easiest way to replicate a part like a battery cover door? Is there a cheap and easy 3D scanning that works? Or is there a reasonably priced service where I can send out a part and get back files??
Thanks
03-11-2020, 12:24 PM #2
there is no simple 3d scanning.
you're looking at around £2-3000+ for a cheap 3d scanner that might work.
But generally with 3d scans you need to do an awful lot of post processing.
The simplest way to replicate a part is with a cad program and digital calipers.
As far as a replication service - define 'reasonably priced'.
Most commercial scanning services start at around £100 an item and don't guarentee exact replication.
So we're back to the diy approach.
Once you get competent with a cad package it's actually fairly quick as well.
As far as functional parts goes - that's pretty much all i design and make.
You might also want to look at resin based machines rather than fdm.
What you are basically asking is can you get something that looks like it's been injection moulded.
Yes - with a resin printer.Last edited by curious aardvark; 03-11-2020 at 12:38 PM.
