Results 1 to 10 of 14
03-10-2020, 10:00 PM #6
- Mar 2020
- Australia
Speaking for the xmax only but it's safe to assume all printers are the same, there's an option to remove or change filaments. It heats the extruder up to your desired temperature and then you select if you want it to feed or retract. You can even pause a print and change filament half way through a print.
The instruction manual for whichever printer you want should be downloadable so you can see how it's done. To extract wait for the head to heat up, hit retract while pulling on the filament and it whips right out
