Results 1 to 10 of 25
12-27-2019, 02:59 PM #19
- Oct 2019
- 52
Thank you.
It turned out I had a bit of problems with connectivity of my Z stop sensor. That was a bit of my own fault as I had to use a bit of soldering to extend the wire.
It's printing now but from some reason every time before the print it starts retracting few cm of the filament.
It's a minor problem for now as I can feed it back manually but after I'm gone go back to flexibles it may cause a lot of problems.
Code://#define FWRETRACT#if ENABLED(FWRETRACT) #define FWRETRACT_AUTORETRACT // Override slicer retractions #if ENABLED(FWRETRACT_AUTORETRACT) #define MIN_AUTORETRACT 0.1 // (mm) Don't convert E moves under this length #define MAX_AUTORETRACT 10.0 // (mm) Don't convert E moves over this length #endif #define RETRACT_LENGTH 3 // (mm) Default retract length (positive value) #define RETRACT_LENGTH_SWAP 13 // (mm) Default swap retract length (positive value) #define RETRACT_FEEDRATE 45 // (mm/s) Default feedrate for retracting #define RETRACT_ZRAISE 0 // (mm) Default retract Z-raise #define RETRACT_RECOVER_LENGTH 0 // (mm) Default additional recover length (added to retract length on recover) #define RETRACT_RECOVER_LENGTH_SWAP 0 // (mm) Default additional swap recover length (added to retract length on recover from toolchange) #define RETRACT_RECOVER_FEEDRATE 8 // (mm/s) Default feedrate for recovering from retraction #define RETRACT_RECOVER_FEEDRATE_SWAP 8 // (mm/s) Default feedrate for recovering from swap retraction #if ENABLED(MIXING_EXTRUDER) //#define RETRACT_SYNC_MIXING // Retract and restore all mixing steppers simultaneously #endif #endif /** * Universal tool change settings. * Applies to all types of extruders except where explicitly noted. */ #if EXTRUDERS >1 // Z raise distance for tool-change, as needed for some extruders #define TOOLCHANGE_ZRAISE 2 // (mm) //#define TOOLCHANGE_NO_RETURN // Never return to the previous position on tool-change // Retract and prime filament on tool-change //#define TOOLCHANGE_FILAMENT_SWAP #if ENABLED(TOOLCHANGE_FILAMENT_SWAP) #define TOOLCHANGE_FIL_SWAP_LENGTH 12 // (mm) #define TOOLCHANGE_FIL_EXTRA_PRIME 2 // (mm) #define TOOLCHANGE_FIL_SWAP_RETRACT_SPEED 3600 // (mm/m) #define TOOLCHANGE_FIL_SWAP_PRIME_SPEED 3600 // (mm/m) #endif /** * Position to park head during tool change. * Doesn't apply to SWITCHING_TOOLHEAD, DUAL_X_CARRIAGE, or PARKING_EXTRUDER */ //#define TOOLCHANGE_PARK #if ENABLED(TOOLCHANGE_PARK) #define TOOLCHANGE_PARK_XY { X_MIN_POS +10, Y_MIN_POS +10 } #define TOOLCHANGE_PARK_XY_FEEDRATE 6000 // (mm/m) #endif #endif
I'm sure this time it's just have to be the settings.
