08-29-2019, 12:10 PM #1
- Aug 2019
- Middle Tennessee
- 8
FlashForge New Creator Pro ont the way - Novice
Well, finally ordered the FlashForge New Creator Pro as my first ever 3D printer. I've never even seen a 3D printer in person. I have some "long ago" experience with CAD but, zero with 3D printing. I didn't want to get too inexpensive a printer and have to overcome machine problems as well as novice problems. Question: Is there anything you might suggest as far as preparation for the printer. I'll only be using PLA for foreseeable future. I have some large air-tight ammo cases for PLA storage. Not likely that I will be printing every day. Anything on workspace are would be helpful.Thank you,Regis
08-30-2019, 05:29 AM #2
good machine. But you should probably have asked first as we wuld have recommended the qidi x pro instead. Essentially the same machine, but with wifi, removeable bed and touchscreen - and a little cheaper.
Things you will probably need:
Sanding blocks
set of mini files, diamond or metal, both work well.
Don't know what print surface they currently use but some cheap gluesticks wouldn't hurt either.
Digital calipers - essential !
Join the flashforge creator pro facebook group :-)
Have a look at openscad for making models.
08-30-2019, 06:45 AM #3
- Aug 2019
- Middle Tennessee
- 8
09-06-2019, 02:51 PM #4
I have a policy that if people ask about specific machines I try to limit replies to that.
Otherwise I'd be all day on every damn post :-)
I mean the one you've ordered is a serious machine, it's just that you could have got more at the same quality for around the same money.
12-21-2019, 12:09 PM #5
- Dec 2019
Pretty much same situation - except I tried my first print today.
Wanted to ask what are calipers for - to check the accuracy of prints? And I hope digital calipers don't have some special synergy with the Creator Pro, since I'm too used to my mechanical ones)
Also, right now they are using aluminium surface with a rough surface sticker glued on.
12-23-2019, 09:23 AM #6
lol, digital calipers are for measuring things you want to make something to: replace, fit or duplicate.
When you start thinking in 10'ths and 100th's of millimetres - mechanical calipers just aren't accurate enough :-)
12-24-2019, 06:19 AM #7
- Dec 2019
I'm not going to get into the mechanical caliper argument here)
But thanks for clarifying. Also, are you implying that 100th's of millimeter is achieveable accuracy for this printer?
