Results 1 to 10 of 36
Thread: GEEETech i3 32bit Rework
12-22-2019, 04:00 PM #1
I have had this printer for over 3 years now. It has seen waves of reworks already and has most of the good parts to include a genuine E3D titan aero, MKS genL mainboard, TMC2208 drivers, MKS tft32 touchscreen, MKS wifi module, 0.9 degree stepper motors everywhere but Z, a 24v power supply with matched heaters, an aluminum bed with proximity switch, and Gates fiber reinforced belts. Here is what all of that looks like assembled together..
12-22-2019, 04:08 PM #2
This printer is limited to a 200mm cube and so I want to chase precision. Making small things accurately. And the only parts I think I am going to add here are a SKR 1.4 Turbo mainboard and 4 or 5 LV8729 stepper drivers all run at 1/128 micro stepping. Past that I want to move all wires to the backside of the frame and design and print some pieces to reinforce or brace the smooth rods. So far I have this piece designed that I will print and mirror and print and install under the Z stepper motors to add support to the threaded rods under the smooth rods for Y. This will keep the top of the frame from flexing forward or the front of Y from shifting to either side. I have designed this part to be a tight fit on the threaded rods..
12-22-2019, 04:15 PM #3
I have decided I want to print these parts in translucent blue PETG. And that spool isn't scheduled to arrive until tomorrow. So for now I will just keep designing the parts. I also wish to do a similar thing with the displays as what I did with my Black Widow rework. It would be cool to have a similar look to my printers. Get my own style going. So I am mounting the displays down low and leaned back at 45 degrees. voltage display from the buck lm2596 step down converter on the left and tft32 touchscreen on the right. I am integrating the display mount and a 20mm tall brace for the lower Z rods into the same part. I still have to produce the design for the right side. Here is my design for the left..
12-22-2019, 10:17 PM #4
12-24-2019, 11:42 PM #5
12-26-2019, 07:28 PM #6
12-26-2019, 07:32 PM #7
12-28-2019, 07:59 PM #8
01-02-2020, 04:43 PM #9
01-02-2020, 05:17 PM #10
