Results 1 to 10 of 25
12-13-2019, 08:00 PM #9
The board will work with your screen but you will need to get silent drivers. I think you should get these: https://www.amazon.co.uk/FYSETC-Subs...dDbGljaz10cnVl . They are silent at 1/64 micro stepping which is achieved with jumpers on for MS0 and MS2 leaving MS1 open. They are also silent at 1/128 micro stepping which does incredible things for your print quality. This is achieved with all 3 jumpers in place under each driver. OR, there is the latest revision TMC2208 drivers here: https://www.amazon.co.uk/KOOKYE-Prin...xpY2s9dHJ1ZQ== . These drivers will be configured with jumpers in MS0 and MS1 leaving MS2 open under each driver. They will run in stealthchop2 with 1/16 micro stepping. and will be quiet with a lower step count per mm of movement. Once you get the quiet drivers up and going Noctua are the real silent fans you want to start getting.
