Results 1 to 10 of 354
Thread: 370mm X 250mm X 300mm
12-10-2019, 08:05 PM #11
Alright. Well that was a little messy. The clear plastic sheeting does not cut so I had to use the Dremel to make the 6 plates. But it is done and here is my clear slightly larger filament buffer.. And here is one of the plates from Prusa set over my buffer to illustrate how much larger my buffer is. Just a little bit..
