12-08-2019, 10:21 AM #1
- Oct 2019
- 52
slicing in 2 parts for support material and the project it self?
Hello!Is there any setting in Cura That allow printing in 2 parts? So I could use for example PVA for support material and to print my project out of TPU?
12-09-2019, 06:59 AM #2
supports usually have their own set of settings anyway.
Even cura should do that. plus if you're using a dual extruder - then the second extruder will also have it's own settings. Just tell it to use the second extruder for supports.
You can't print support then print a print with a single extruder printer. as the print head would knock the support out of the way.
12-09-2019, 03:35 PM #3
- Oct 2019
- 52
Well yes wanted to know if it's possible to do it somehow with a single extruder. I'm planning to use TPU but will try my best to get it clean. But thank you
