Results 11 to 15 of 15
Thread: Looking for PETG Tip
09-05-2019, 07:10 PM #11
- May 2018
- 629
Ok, Not sure that can be done but if not pm me and I will send you my email address.
I think your machine is a direct drive extruder as is mine, you may want to try to reduce your retraction by about half and slow it down. I don't like to have retraction set a lot faster than print speed. Not sure it matters but has always worked for me.
Here are 2 models to print using your PETG settings.
one is a 2 walled square and once printed, it should be 2mm tall and the walls should be .8mm thick.
The second is a 2 layer square which should have NO gaps between the threads and should be .4mm thick. If there are gaps raise your.. I think it said flow rate? It was set to 102% in your settings..
09-06-2019, 09:48 AM #12
- May 2018
- 629
Qwiktune, how did your cal squares turn out? I set up my printer up for PETG and took a few photos of the calibration squared and if you click on the thumbnails there is more info under the big pictures https://misc.airscapesart.com/calibration/index.html
I printed your part but forgot to enable support, second copy is printing now. Will post photos when it is done. If you live in the US I would be happy to mail the part to you just in case you can not get this working on your machine.
BTW I am printing at .3mm not .2
09-06-2019, 10:49 AM #13
- Jan 2019
- 24
I wasnt able to get to it. I had actually bought another printer, (Ender 3x) so I had a print I could do prototyping on while printing parts on the other, and ended up putting it together last night. I'll do it tonight though and see what happens.
I live in USA [PA] and that would be cool. One goes on each side (so you would essentially just mirror the bracket to print the opposite side). Would be good to have a pair properly printed to reference, but my ultimate goal was reproducing these (as well as other brackets and things) for a number of people in my car community where this part (metal) from the dealer has been out of production for quite sometime.
09-06-2019, 11:40 AM #14
- May 2018
- 629
Sending you a PM, I am just outside Philadelphia
I added a bunch of pictures after the calibration info.
Calibration squares and your part in PETG
11-02-2019, 11:48 AM #15
- Jan 2019
- 24
I'm already improved it by changing my retraction to 1 from 3. Theres still a hair of stringing by its easily cut with a blade. I think my problem was when it switched from the leg with the holes over to the pillar it was way under extruding becuz of the retraction. I havent tried printing much anything else since i've been printing the hell of these brackets as I sell them so i wanted to print a whole bunch while I got it printing good before i adjust anything
Login Error
