10-13-2019, 08:29 AM #1
- Oct 2019
Support Material For Concrete 3d Printing
Hello guys,
I will be working on my thesis this year. I am willing to create an extruder for 3d printing concrete. I want to use a secondary material as a support that will print with concrete at the same time. Once the concrete is cured I will remove this support material. I was thinking to use clay or wax as secondary material. I want to ask if there is any other material that I can focus on during my research which should be easy to remove once the process is complete. I can be water-soluble, melt with heat (Like Wax)...etc.
Let me know if you guys can think of any other material. I don't have a lot of money or infrastructure to work with advanced materials such as metal, polymers...etc. So the materials should be easy to find and work with.
10-13-2019, 10:23 AM #2
never seen support material on concrete printers. The trick seems to be getting the consistency and recipe of the cement stiff enough to hold it's own shape.
Depends on how large an item you intend to print. You could go with recycled plastic that would melt out fairly easily.
11-08-2019, 04:02 AM #3
- Nov 2019
- USA
Hello guy!
Brief me,
I can help you.
Thanks....
