10-11-2019, 02:57 AM #1
- Oct 2019
Modifying The controller of 3D printer
How can i possibly replace my 8 bit controller of 3d printer with a 32 bit controller.I have heard that 32 bit controller offer more speed of printing than 8 bit .Could anyone guide me and suggest me the best controllers .
Note:i am completely new in this field
10-11-2019, 06:01 AM #2
There are many 3D Printer 32 bit controllers. Some are quite compatible with there 8 bit counterparts.
This means that the same firmware can be used on both so that it can be complied as 8 bit or as 32bit.
The firmware is still being developed and there are still some bugs though you can look at a list here.
https://hackaday.com/2019/05/10/a-32...ur-3d-printer/
10-11-2019, 06:17 AM #3
- Oct 2019
10-11-2019, 06:29 AM #4
speed and quality won't change much.
That depends more on your stepper notor controllers, so if they're better, then - yep could be some improvements.
But speed and quality are more down to the actual mechanics of the printer than the electronics - in my opinion anyway.
The current popular board in the 'cheap as chips' section is the skr 1.3: https://www.youtube.com/watch?v=GNGN2iSQ5j4
The mks base is also popular. Think autowiz is using all mks base's in his machines.
The main advantage of a 32 bit board is smoothieware :-)
Probably the easiest firmware to setup and configure around.
10-11-2019, 06:58 AM #5
- Oct 2019
10-11-2019, 09:43 AM #6
just do a web search.
If you can't do that - then you've got no chance in changing a board :-)
