Results 1 to 10 of 39
10-10-2019, 12:33 PM #30
- May 2018
- 566
if you are using a .3 layer than you Z offset is .6 too high and why you are having adhesion issues
I can provide instructions MG support gave me when I first got may machine and realized the quick start thing was not very good..
How to alter your Z-offset with the M2 Rev. E:
You can fine tune the bed height without the QuickStart App. It involves sending gcode commands to your printer which can be done in the QuickStart App, PronterFace, or the Machine Control Panel in Simplify3D.
1. Reset your printer so that you are only saving the changed Z-offset to your Rambo board. Navigate to whatever communication platform you choose. And connect to your printer.
2. It may start updating with temperatures every few seconds. It is best to shut this off. (For example, in the Machine Control Panel of S3D press the “Verbose” radio button.)
3. Next, send a “M503” command. This will display your printers settings stored in EEPROM.
4. Look for an M206 in the communication window, these are your offsets for every axis. Then find what value is set for Z. It should be something around 10 to 14 (the unit is millimeters).
5. If you make this value larger your bed will start closer and if you make it smaller your bed will start further away.
6. Enter a new z-offset with “M206 Zxxx” (replace xxx with whatever number you want).
7. Send a “M500” to save the Z-offset to your printer.
8. The new offset will only be used after you home the Z-axis. this can be accomplished by printing something (most gcode has a homing command at the beginning) or manually sending a “G28Last edited by airscapes; 10-10-2019 at 12:57 PM.
