10-08-2019, 01:56 PM #1
- Oct 2019
Question about hollowing out a 3D Model
Hi all! At what scale/size should you consider hollowing out a 3D Model?
I want to print at 1:12 scale, should I consider hollowing out the model?
a noob question, I know! Thanks for your answers!
10-08-2019, 04:24 PM #2
- 885
If you are using FFF/FDM printing, you don't have to hollow the model. A low infill percentage will give the model internal strength without excessive filament use.
If you are using a resin printer, just about every model should be hollow, except for those that are so small that the wall thickness matches the horizontal resolution of the printer. For example, I had a request for a resin printed model which was 2 mm wide by 4 mm long and 1 mm tall. It's not practical to hollow something so tiny, but the part had a hole in the design that allowed for drainage anyway.
