Results 1 to 10 of 16
Thread: ABS Cracks and Gaps
09-18-2019, 02:37 PM #5
- Sep 2019
I find that sharp or sharper corners are normally where the cracks propagate from. There is a good reason for this called stress raisers if you want to research it. If you dial up your heat or dial down your speed and reduce sharp corners it will help a lot.
