Results 1 to 10 of 11
04-20-2014, 06:32 PM #1
- Apr 2014
Come3d, not calibrated properly. Really need help
My problem is that when i use the default calibration profile the platform all ways goes off into the right side of the printer and keeps trying to go that way. Also the extruder just goes all the way up and then comes down a little but doesn't get anywhere near the bottom where it should.
So when i set them both to center in the control panel, it does that perfectly. I even set the X,Y,Z to 0,0,0,0 on the motherboard settings, but as soon as i try to print, there goes the platform off to the side and continuously hitting it.
I don't have a clue what i'm doing wrong, it says to load the calibration profile and press build, but that just makes the extruder and platform do the things i just talked about.
Is there anyone that can help me with this? I could upload a video if necessary? Would really appreciate the help!
Thanks
04-21-2014, 03:09 AM #2
Don't bother uploading a video. Tell us about the operating system and the electronics. There is precious little about this printer on the Net.
Old Man Emu
04-21-2014, 06:27 AM #3
- Apr 2014
Hi there, the following information is off the manual. Edit::: Iv'e just read the manual and for calibrating it says to revolve the Z-axis down to the platform but not touching and making sure there both centered ( which i did). It then says to use the provided script *Thing-O-Matic Calibration* After choosing that and allowing it to do it's thing, it talks about the platform X-Axis will move to the right, and Y-Axis moves backwards and when confronted with the limit switch will be stopped respectfully. Only problem is that it seems to only do the X-axis and then hits the limit switch, it doesn't even go to Y-Axis. When i actually go to print it just hits the limit switch 10 times and then moves to the left, stops for 20 seconds and then starts to print, problem with that is it tries to print no were near the extruder, so it just lets out the stuff and falls off onto the printer as the platform is off printing somewhere else??? do have any clue what this could be?
Position accuracy. 0.1mm
Print precision. 0.1-0.3 mm
Layer thickness. 0.3mm
Speed: 15cm/ hour
Build size: 120x120x120 mm
Nozzle aperture 0.4mm
Power requirements 220V300W, ATX
Comparability Windows, ( I use Windows 7 64 Bit )
CE, CSA specification, CE, CSA
That's it. Do i need to provide anything else?
Many thanksLast edited by arkcreations; 04-21-2014 at 07:04 AM.
04-21-2014, 07:02 AM #4
Are you able to open the printer up so that you can see the controller board? If you can, please post a photo?
What we are trying to find out is what is running the printer, and can we work out the firmware. Once we can do this, the solution to your problem might be arrived at easily.
OME
04-21-2014, 07:06 AM #5
- Apr 2014
04-21-2014, 12:20 PM #6
- Apr 2014
Hello,
I also have this printer, similar problem.
During calibration all 3 axis drive to the limit switches and the red light activates, but the axis keeps on driving.
The hardware being used is Makerbot mother board v2.4. I am running firmware 3.5 and extruder firmware 3.1.
Z axis was recognising end stock initially but now Keeps driving.
hope you can help.
06-19-2014, 04:51 AM #7
- 6
Hello I have also just purchased this and has just arrived, i am wondering whether it is possible to run this on mac osx platform?
02-03-2015, 08:54 AM #8
- 6
HAs anybody got problems with it not sticking on the platform? Im using ABS and it warps of ont he thrid layer no matter how big the model is
02-04-2015, 07:01 AM #9
02-04-2015, 10:34 AM #10
- Feb 2015
- 13
Woah, woah. Did I read that correctly? 0.3mm maximum layer height? Everything I'm reading about this one scares me a little. I have yet to see someone say that they bought one, calibrated it, and got it to work.
